GregBe
- Jul 9, 2003
I am in the process of updating my home theater, and I have a question about subs. I understand there is a direct correlation between sub size and performance. In order to get a smaller sub to perform well, it is going to cost a heck of a lot more than the same performance from a larger one. My question, is where are the lines drawn?
I currently own a Cambridge Soundworks P1000 sub. It lists for $1000, although I paid much less for it. It is about 14" cubed and is a great sealed tight bass sub that does pretty well for its size. I can adjust the cutoff for output vs. extension. It will play down to 22hz, but at a reduced level. To get any kind of substantial output, I have to have it roll off at 30hz. It will still play pretty solid down to 25hz at that setting.
I can go larger than I have right now, but the size of the SVS PB10 is about as large as I can go. The problem I have is size, not money. Although I can't go larger than the PB10, I can spend more. Are there better subs out there than the PB10 that are smaller, even at much higher prices? The HSU VTF-3 is probably going to be too deep for my room. Has anyone compared the PB10 to the Paradigm Seismic 12 or the Veodyne SPL1200 or Velo DD12?
Greg
Greg
