John Menoni
- Feb 29, 2004
I was so excited to see what the SVS would sound like in my room. I currently have an M&K 350 sub. It is an awesome sub but it just doesn't have the muscle of the SVS PB 12 plus 2 that I was anticipating buying. I am really getting alot done and I started taking measurements. There isn't that many places that the sub can go in my room. It is a problem room to say the least. Still I made the most of it and it should still be pretty cool. I was so angry to find that the SVS would actually cover the screen material on my screen. There is no way that I can use this sub in the front of my room. I looked for an alternate place and there really is no other place that really seems feasable. The only place would be between the back and front seating area. I'm just afraid that this area is too close to the listener and the bass wouldn't have a chance to develop. Then I thought that I would build the sub into the stand that I need to put my projector on. That is no good either because the SVS is too high for that. The only other option would be to lay the SVS on it's side. I know that isn't the way the sub is meant to be so I figure it must effect the sound in some negative way. Any other ideas would be appreciated. I have a diagram of my room but I can't figure how to get it on here. Basically my room has very very low ceilings at 6 1/2 feet and go even lower in some places because of overhead pipes. The room is 26 ft long but only 79 inces wide in the narrowest part of the seating area. The whole room is a hard C shaped room so the HT is in the long part of the hard C. I guess I will just have to go to war with the M&K.
