ChrisLazarko
- Aug 13, 2003
Ok guys, here is what I am trying to do. I have split my subwoofer connection off from my reciever to make two channels basically of the same material, (Y Adapter) and have it going into the Left and Right channels of my EQ.
I have one of the channels hooked up to my Polk Audio subwoofer, and the other channel going into my other reciever's left channel to provide power for my Bose Acoustimass module, but there isn't enough power to give good bass unless I have both channels. Without using another Y Adapter how else would I be able to make a connection? I was thinking of chopping off part of an audio plug (the red and white ones) and then putting a small portion of the bare wire, putting it in the Left audio channel plug, then hooking the atually RCA part into the right channel.
It sounds kind of confusing, but I am trying to figure out how to do this using only what I have. I appreciate any replies. Thank you.
