Joe Pick
- Jan 12, 2004
I have an Onkyo TX-SR703 A/V, which is connected to a 5.1 setup of PSB Image speakers, including a SubSonic subwoofer.
On the sub, I've read instructions, but I'm wondering if someone can give me a "ballpark" idea for the "Sub Cut-Off Frequency" and "Phase Control" settings. Right now they're set at 90 and 0. The volume is a tick or two past the middle.
On my receiver, there's a "Low-Pass Filter for the LFE Channel", and my choices are 80Hz, 90Hz, 100Hz or 120Hz. Right now it's set at 90Hz, since the 80Hz setting is for THX speakers, which mine are not.
Also on the receiver, there's a "Subwoofer Mode" which I've set to "Double Bass"
Should the sub's "Sub Cut-Off Frequency" and the Onkyo's "Low-Pass Filter for the LFE Channel" be set to the same number? That's why I chose 90 for both. I used the Onkyo's auto setup, which does not set these settings, by the way.
I guess it sounds OK to me - DVDs are better that HDTV's audio, but I'm wondering if someone who knows what they're doing might cringe if they heard it. Thanks!
