Sebastian
- Apr 14, 2002
If you want the cleanest possible cut when cutting through MDF or Baltic Birch 13 plywood,
Is the only difference between the two bits is good face up/down when cutting?
Or is one better than the other?
I will be cutting circles for sonotube end caps.
