Mike Broadman
- Aug 24, 2001
Hey, folks, this is a question about my parent's TV setup:
They have a simple cable/VCR/TV setup:
Regular analog cable w/ cable box. Coax from box to VCR, coax from VCR to TV.
The problem is, if they try to record something, the sound is all quiet and muffled. They have to crank the sound on the TV up to un-godly levels to get any sound onto the tape.
Also, if you turn the sound low, you hear a muffled whispering-type distorted sound.
Are there some setup issues I should be aware of? I'm going to visit my parents this weekend and will be giving them and installing my DVD player. While I'm poking around, I may as well check out anything you guys have to suggest. Thanks.
