Nathan Beyeler
- Aug 7, 2004
I'm going to upgrade from my 27" Sony Trinitron. I looked at a 30" HDTV 16:9 screen (thanks for the recommendation Bill Will) but it won't fit in the cabinet. I'm fine with staying with a 4:3 screen. DVD 16:9 with black bars on top and bottom is fine for us.
After some research I found the following two sets.
Sony KV-27HS420
HDTV Ready / $712 at Circuit City
Samsung TX-P2775H
HDTV Integrated / $665 at Circuit City
Does anyone own either of these?
How can the Sony be more expensive but only be HDTV ready?
Which one would you recommend?
Nathan Beyeler
[email protected]
Sony KV-27HS420
Samsung TX-P2775H
Nathan Beyeler
[email protected]
