Razvan V
- Aug 28, 2000
I went to the Good Guys last night and they had the DA5ES on display. It does have DPLII and DTS Neo 6, you can activate them by pressing the surround button behind the front plastic door. I didn't listen to it but I noticed that its transformer is pretty big, as big as the DA777ES transformer I think. Its capacitors are much smaller than 777's though. Its build quality is MUCH better than the V series receivers but not as good as the 777. The volume control seemed to be OK but, as you know, it might get bad with time. The unit was made in Malaysia.
Razvan
Razvan
