Yumbo
- Sep 13, 1999
- Chris Caine
are both editions 'cold'?
or is either worth picking up?
thanks
thanks
The AR is a little under 1.66:1 (looks around 1.60:1 on my DVD-ROM), so 16x9 wouldn't add a lot of resolution.However, if you own a 16x9 TV, the 1.66:1 ratio is the absolute worst for displaying as non-anamorphic, IMO. In order to view the film without image distortion or cropping, you are forced to watch an image that is both windowboxed and pillarboxed.
I usually avoid non-anamorphic 1.66:1 transfers for the above reason (my Panasonic RP-91 does a great job of scaling 1.85:1 or wider non-anamorphics). However, I do make an exception for truly great films such as Some Like It Hot. Other than the non-anamorphic issue, the transfer looks decent.
