Anyone know of any portable tuners for sirius that are similar to the jvc and xact ones. I am looking for one I can take from home, car, and personal use.
I'm assuming since you mentioned the JVC and Xact brands that you're looking for a "PDA style" plug N play unit? As far as I know those are the only two with those type styles. But as far as being portable ALL the plug N play models are to an extent....as long as you have a home/car docking kit and a boombox. I personally have the Sportster Replay and would highly recommend it.
But if you're referring to a portable style like a Sony Walkman then you should check out the Xact ReGo.
