Richard_M
- Feb 8, 2001
I am using B&W 603S2 for mains which are good to 48 Hz approx. The mains & centre are being driven by a Rotel power amp so power is not an issue. I have been offered a Yamaha YST-305 Subwoofer cheap and was wondering if hanging it off my mains and making them large would be a good move.
I find that if I set my mains to large music sounds more natural especially Eric Clapton guitar playing. Currently all speakers set to small 80 Hz xover Denon 3802
The Yamaha sub should be good to 30 Hz. I was thinking cross over sub at 50 Hz and run test sweep 2 Hz steps (.1 subs off) from say 30 - 100 Hz to try and match sub to the mains
Is 30 Hz enough for main speakers, and would the Yamaha sub be able to keep up to ref levels? Not that I usually listen at ref levels.
Also would the new sub react with my .1 subs as far as cancellations and peaks are concerned?
Richard
Richard
