Brad_Harper
- Jul 5, 2001
Actually speakers can be capacitive (electrostatics) or inductive (any speaker with a cone woofer). Neither of these will affect the signal coming from a CD player (any source) to the amplifier. The input to an amp is seen by the source as a resistor; most of the time it is apporx 10Kohms. So using a scope to view the signal is perfectly valid. To view amplifier output one just has to put the scope into parallel with whatever speaker you have hooked up. Seeing as the impedance of the speaker is low (8 ohms) and the scopes impedeance is very high (millions of ohms) the impedance of the entire circuit seen by the amp will not be change by any signifcant amount.
8 ohms in parallel with 1 Mohm = a circuit with an impedance of 7.9936 ohms. Not anywhere near enough to affect any waveforms.
