Bill Kane
- Feb 5, 2001
ack! sardonic thread poop!
The dread surge can find the back door thru the tv into the system and one is SOOL.I read this on the Power Systems site when I purchased my Panamax, that is why everything goes through the Max, including my cable - again, even your cable TV line can carry a lightning strike to your gear just as easily as your power wires.
how does this work if you have the receiver plugged into itself? JKMy Marantz has two outlets on the back, C'mon Daniel
Truth be told, I have my receivers cooling fan plugged into the back of the receiver, that's all.
Peace Out~
The MPB-2100 has 3 discrete filter sections: 1 low current audio (4 outlets), one high current audio (2 outlets), and 1 video (6 outlets). This prevents different types of equipment from interfering with each other. The unit uses stage 2 filtering, and does a little better job than the 2000 does.
Source: discountpanamax.com
edit: Anyone else, wud you plug a RPTV in the Monster's "high-current" outlet if you had the opportunity, or rely on the Video outlet?
bill
