Ryan Peddle
- Nov 28, 1999
I have studied and read over many online documents about using baffle step compensation to correct the final sound of my diy speakers due to them have a thin sound with lett bass response.
The problem I am having now is that all the documents I have read tell you how to fix it and I have calculated the proper component values, but does this new circuit completely replace the previous crossover circuit or add on in addition?
Thanks in advance.
Thanks in advance.
