Patrick Sun
- Jun 30, 1999
Can you "retrofit" an existing PC setup (single hard drive) into a RAID 1 config (2 hard drives mirrored, connected to a RAID card)?
Or is it better to start from scratch (have both hard drives connected to an installed RAID card and then load the operating system, etc on the hard drives)?
The reason I ask is that I have everything but the RAID card, so just trying to find out if I can get started before the RAID card shows up.
