Kent Wo
- Aug 25, 2001
I have a 36HF72 Toshiba and can't seem to get the picture quality as good as I'd like it to be. I've set up the TV using Avia, but with digital cable the picture still looks crappy. Is there any way to improve on the picture quality? I've been using digital cable with the HDTV box and component outputs straight to the set. For one thing the picture comes out compressed in on the sides (not the top and bottom though) and a little fuzzy even on the HD stations and shows. Is there anything I can do about it or is the clarity a reflection of the higher line rate multiplying the static of regular TV?
When I used the same cables and everything and just switch the cable box for the DVD player things work fine. Though even that picture could be better, or maybe I just have too high expectations for my HDTV.
BTW: I'd appreciate quick help since I have a cable guy coming in a couple days and I'd like to solve this problem without his help if possible since they charge for that type of service.
