Geoff L
- Dec 9, 2000
- Geoff
For those that may have heard all of the 2-channel amps mentioned or 2 of the 3, curious as to your take on any of the Amps mentioned...
Which might you prefer driving (2-channel full range audio) for SQ at med to moderate volumes?
There are so many variables that effect SQ. The Pre, the Transport, the Material being played, the Speakers being driven, and of course the room & it's size.
All these amps have been reviewed and received high marks as excellent preforming pieces.
I belive all are very decent quailty amps, with the AS-Amp2 being a unbelivable sleeper according the many reviews I've read.
Carvers~TFM-15-->not 15CB
Adcoms~GFA-535-->not 535II
AudioS~Amp Two-->not Amp1 with meters
Given a choice which Amp would you take if you "had to pick one" and why you may feel that way?
Any input good, bad, or other, would be very appreciated..I left speakers being driven and all other variables out on purpose.
Picking an amp from the Amps ruputation as an all round good performer with all other variables left out,,, as they can always change & usually do in time.
Geoff
Geoff
