Question About 4K Viewing (1 Viewer)
stevenHa
I haven't set up my 4K player yet but from people who have - do you need different TV settings to view a 4K disc as opposed to a regular blu ray disc ?
Jesse Skeen
My TV switches to a different mode with different settings- you can make adjustments on it which won’t affect the settings for 1080. It’s a bit hard to set as I’ve never found any test patterns in 4K, there are some on Sony discs but they don’t include color bars!
Tino
Taken As Ballast
Metro NYC
Valentino
Which 4K display do you have?
Some displays require you to turn on deep color on the television (and/or in the player) before it will display the full rec. 2020 UHD picture with HDR.
stevenHa
I have a 65 inch LG OLED - I saw a comparison on YOUTUBE for Warcraft and the film was very dark and didn't match the blu ray until the settings were changed according to what was appropriate for 4K. Having to play around with the settings if I switch back and forth between regular viewing/blu rays and 4K seems very bothersome.
Scott Merryfield
Mich. & S. Carolina
Scott Merryfield
As mentioned above, some displays store separate settings for different formats. For example, my Vizio M70-D3 stores settings for SDR, HDR10 and Dolby Vision and automatically loads the proper saved settings as the format changes. There are quite a few LG OLED owners here, so I am sure someone can provide insight on how its settings work.
So does the LG OLED, Steven, so you won't have to worry about switching settings once you get them dialed in to start. The TV will do it automatically depending on what the player transmits.
stevenHa
So I just get the TV calibrated in one mode for everything (Geek Guys usually calibrate one picture mode like Expert daylight) or do I have to get an additional mode calibrated like HDR mode for the 4K material ?
Scott Merryfield
Mich. & S. Carolina
Scott Merryfield
If your LG display is like my Vizio, each mode will need a unique calibration. In the case of my Vizio, I had to actually feed the display each of three modes (SDR, HDR10 and Dolby Vision) in order to calibrate for each. I doubt any displays out there are optimal using the same settings for different modes.
TheThrillisgone
