Jack Briggs
- Jun 3, 1999
Guys, debating this issue is perfectly fine. But let's don't let it get personal. Please. Thanks.
-Martin Luther King, Jr.taste said:Quote:
Can it? What instrument would you propose we use to measure taste?
If copper is putting a taste in the water (just humoring you- as if the copper pipes in your house would add more "taste" than the MILES of pipes leading to your abode already have), the substance causing the taste, or the chemical reaction causing the taste, could both be seen in a chemical analysis of the water before it enters your house against a sample coming out of your tap.
Hey RicP, since copper pipes are such an offender to the palet, perhaps you could make a line of "fresh tasting" high-end plumbing pipes! You could be a multi-millionaire!
Oh well. I'm off to get a glass of copper... I mean water.
If it weren't so late, I might even go listen to some interconnects...I mean music
"I have a dream..." that one day the cable-believers will quit the talking and get to proving their claims in a controlled blind test
Can you believe I got through this thread without my backwoods, redneck, in-bred, southern slang hindering me? Yee Haw! Now, you's guy's have a good night now, ah-ight.
How many of you believe that either different interconnects or speaker cables can sound different in a stereo system, all else being equal?
I do.
Jim, if the last 1ft of pipe in your house say wasn't made out of copper, but just plain old steel. Now let's say that pipe is all rusty and grungy and such.
Will that piece of the pipe effect the taste of the water?
Andrew
Jim, if the last 1ft of pipe in your house say wasn't made out of copper, but just plain old steel. Now let's say that pipe is all rusty and grungy and such. Will that piece of the pipe effect the taste of the water?
If you poured a cup of water from the tap as soon as you turned it on, yes. If you let the water run for a few miuntes, then no. I actually used to have a house with old rusted galvanized plumbing, so I speak from experience. Point is, that I'd equate that small piece of rusted out pipe that contaminates the water with a perfectly functioning Radio Shack interconnect that my dog chewed in one spot, damaging the integrity of the conductor, dilectric and shield
Meanwhile, the more cynical among cable manufacturers continue to make money by the bucketloads, because some of us believe - or tend to trick ourselves into believing - that the more expensive the cable, the better the sound. This, I think - although there may be certain slight differences in sound characteristics - is merely hype, a marketing stroke of genious, more than anything else.
Well, the Forbes list just came out and I have yet to see a single cable company on the list, must not be that much money in it (none of them are in the private business Forbes list either).
And why does every non-believer say that us believers think a cable that is more expensive that it will be better? I have tested out only a few cables (compared to what's out there) and I've found that probably less than half the time do I prefer the sound of the more expensive cable. In fact I replaced a bunch of cable in my system that were half the cost of their originals...so much for placebo effect and that desire to justify the cost (when I have box full of expensive cables sitting in my closet).
Andrew
Differnent recievers sound different
Different amps sound different
Different tv's look different
Different speakers sound different
So then why would interconnects sound different?
I've NEVER seen any of these things made from a single wire
