MuneebM
- Jan 12, 2004
I currently have 2 subwoofers in my home theater basement: a 2500 cubic ft. room with padded carpet over concrete floors. My primary sub is an HSU STF-2 located in the front left corner of the room, and my secondary sub is a modified Dayton with an STF-2 driver located in the rear right of the room. I determined these locations to be the most ideal after trying different spots and plotting my 1/6th octave frequency response.
Now, I'm pretty happy with the almost flat frequency response I'm getting out of these two subs, especially considering how difficult it is to do that with two very different subwoofers. However, I now have 2 different frequency response curves and I can't decide which one is best. The first one is when I set my AVR's (Yamaha RX-V2400) subwoofer distance to 2.0 ft, and the second one is when the same parameter is set to 10.0 ft, which is the distance determined by the Yamaha's YPAO auto calibration system.
Here's the first curve, with SWFR distance set to 2.0 ft:
and here's the second curve, with SWFR distance set to 10.0 ft:
So, which one would you all choose? They both look nearly flat to me, with a few minor dips and peaks, which frankly I won't be able to do anything about short of buying a BFD. These two curves are currently my only options, so please try to work your suggestions around those.
Thanks in advance.
http://207.107.210.136/sigserv/pl/index.pl?p=1
My DVD Collection
Thanks in advance.
My DVD Collection
