Ryan T
- Sep 10, 2001
Hi,
I was just looking through the PE website and found this finished subwoofer cabinet. Here is the link..... http://www.partsexpress.com/pe/showd...14734&CATID=48
I was going to try and build a sub box for my shiva but turns out that I will not be able to. I was just going to have to settle for a car sub box made for two subs. I was going to cut out the middle divider and cover up the other sub hole to get a box big enough. When I saw this I was really happy because I have been searching for a well made sub box for a while and found nothing until now. The picture shows that it has internal bracing and it looks well build also it is supposed to be made with 1" MDF. I’m wondering if anyone here owns one of these or could recommend this or any other premade box in this price range. How well do you think a shiva will perform in this box? If you could give me any advice it would be much appreciated.
Ryan
Ryan
