Kathy C.
- Aug 7, 2002
I'm new to this and trying to build a decent HT on a tight budget, by trying to pick up some used gear. So far I have a "mint" Paradigm pdr-10 sub, and have on way 2 Paradigm mini's(v.2). My plan was to find 2 more minis, and the cc370 or 350. Now, I'm wondering if I would do better with some B&W 303's, but am not sure how the b&w lcr-3 center compares to the para cc370.
Some people really complain about difficulty placing the minis for the best sound. My room is tight, and I may have a problem placing the rears. Do the b&W's have this same issue, with rear ports {?} ?
I can still use the Paradigm sub, so that's no problem, and can probably sell the mini's if I need to. We listen- movies/music about 60/40. My room is about 17x15. Please help!!
[also can use some advice on best 400-500$ receiver for this set up]
thanks in advance-Kathy
