BobP
- Jun 13, 2003
A possible upgrade to my system quandry here. Currently I have the following setup:
Denon 3802
Titans v.3
CC-170 v.3
ADP-170 v.3
SVS 22-31 Pci
Here is my question, I have the possibility of upgrading to some Mini-monitor for the fronts, but they are only v.2's.
Eventually I would upgrade the center to a CC-370 but will not be able to just yet. My question is has anyone noticed a "noticable" difference in past versions to new, and also using a CC-170 with the Minis? According to the Paradigm website, they show with the minis you can use ADP-170's, but say to use either CC-270's or 370's. Quick note is my room is quite small, so I am able to play at easily below reference level and have the wife complain about the "noise"
factor. Room is roughly 12x11x7 so the Titans and CC-170 fill the room wonderfully, but I have read here before how much better the Mini-monitors are and that it is a "big" difference from the Titans.
Thank you all for any help.
Denon 3802
Titans v.3
CC-170 v.3
ADP-170 v.3
SVS 22-31 Pci
