Jody_R
- Nov 21, 2004
First off, my apartment isn't ideal for sound. It's long and narrow and the speakers will be firing towards floor to ceiling windows that are covered with fabric vertical blinds about 20 feet from their location. The speakers will be a max of about 4-5ft apart, and I don't have any choice but to have them about 1ft from the back wall. The right front speaker will be positioned about 6" from a side wall, however the left front won't be. It's all hardwood floors atm, although that's easy enough to fix.
The mix is about 70/30 music/ht and I listen to a lot of classical with the occasional Nine Inch Nails.
Right now I'm using some old JBL 800s which are very bleh. They were very boomy, but then I had the idea of stickign socks in the rear port and they started sounding a lot better...
I've read that the reference studios can be picky about placement. Will my room be a problem for them? They are front ported, so I'm hoping that'll help. Still, they're gonna be really close to the walls...
My next questions is in regards to a sub. I live in an apt building, and although it's solid concrete (obviously) and I can't hear anything beside me, sound does escape out the front door and travel all the way down the hall. For this reason, I was questioning the purchase of a sub. Would studio 40s be fine for HT without a sub? I could maybe go with 60s instead.. Although that my exacerbate my problem with being close to walls as I think they're rear ported. Space is also an issue.. I don't really know where I would put a sub.. definitely not at the front, so it would have to be crossed-over pretty low so that i didnt know where teh sound was coming from.
Lastly, I am on a budget. I can only afford the 40s and a receiver at first. Given the closeness of the two front speakers though, do you think a center would be the next thing to buy? Or should i get the ADP-470s next? Assuming I go with paradigm of course...
