Hello,
I was wondering if anyone has any suggestions or alternatives to buying HI PRICED Wall plates.
My thought is this. My AV rack will be located at the back of my room in the corner. It will be in-closed in a cabinet making it very difficult to plug into for things such as laptops, video cameras, game consoles etc.
What I thought I would do is terminate a AV gang box either at the front of the room on the same wall as the Screen, or at the front of the room but on one of the side walls. I am inclined to choose the front wall because I figure if I want to plug in a console or computer that would make it easiest.
My requirements for termination are as follows:
Component Video - 3 RCA jacks RGB
Digital Coax Audio - 1 RCA jack
S-video - 1 S-video jack
VGA - 1 VGA jack
Analog Audio - 2 RCA Jacks (Red, White)
Analog Video - 1 RCA Jack (Yellow)
1 RJ45 - Ethernet Jack
Does anyone have experience with this type of install. I have purchased all the applicable cable, and am ready to run it to the location I am concerned about HOW BIG of a Gang box to use... Double Gang, Triple Gang, Or two single gangs, three single gangs...
Not sure what to do.
I was also thinking of simply adding female ends to all the cables coming out of the wall then Just putting a flip open Face plate double gang size, and pulling out the wires when I need them. I figure this is allot cheaper than the 200.00 face plates I will need to buy, Plus I have looked everywhere for that type of face plate and cannot find on anywhere.
PLEASE HELP ... Make a suggestion... I need advice, and Ideas...
Do you think a simple flip open Faceplate with the wires inside the wall pulled out when I need them will work or is this a stupid idea...
VGA - 1 VGA jack
