John Tompkins
- Aug 30, 2000
Switched lex to ICBM for side bass enhance that is
A while back somebody had mentioned that you could use the icbm in a 4th order fashion by hooking up from one icbm output to another icbm input, thereby using two channels of the icbm (stacked) together.
In other words, you would run from pre out to the icbm input and then icbm output to another icbm input and out again, effectively giving you a 4th order bypass for each channel that has been doubled up. Is there anything to be gained by doing this ?
