NEWBIE with DVD player help?? (1 Viewer)
braden
Trying to finish HT...
Looking for DVD player for about $200.00
Currently using a Mitsubishi Gold Series 1080 65inHDTV
I just received the my SVS 20-39PCi today and awaiting arrival of the HK AVR630...
Also, any suggestions on cable to hook all this stuff?
braden
Have been researching , and I think I will need one with capabilities to change High Definition signal (HD) (720p/1080i). Is this the correct assumption. I beleive I aslo have a DVI port on TV but not for sure about Receiver. My cable box is running into the DVI port now. (I think)
are these anygood??
Zenith DVB318 $250
Samsung 931 $180
Please help me, I do not know the technical terms, but I want to get full use from my HDTV...
John S
The Denon 1910 us also getting some pretty good press / reviews these days.
The dang Zenith, has lost a lot of it's advantage with the more recent build dates.
If your only DVI connection is being used by another device, probably best really be focusing on finding a really good 480p player on Component Video.
andriesprice
