lukeharrington
- Apr 1, 2010
- luke Harrington
Hi guys, Im using a pioneer 819 receiver with 2 polk monitor 60's front and 50's rear with a polk cs2 center. I have been using a cheap sony saw2500 10 inch sub but recently came about a second one. So i decided I would stand my two fronts on top of the two subs to clean up my floor area. ( they fit perfectly, and do not rattle) Im using one cable from the sub out port on the receiver to a splitter from radio shack and a cable to each sub. My problem is that it seems i now have less bass than i had before? I have the subs set exactly the same as far as the crossovers on the rear and the volume and both in standard( ie not reverse mode) . I have the crossover on the receiver set at 80 hz. Im at a loss for what may be wrong here!! Thanks so much for the help.
