Jay_Via
- Oct 28, 2001
Hi all, im working on refinishing the main area of my basement into a home theatre and ive got a few questions, primarily about walls and electrical.
First, a brief history. The basement was finished in the mid-70s and consisted of an ugly linoleum floor, dark paneling and a 12"x12" tile ceiling. The paneling and ceiling have come down because the former owners were heavy smokers and it was pretty nasty down there.
The room itself is 12'8"x23' and has the foundation as 2 walls.
Heres my wall questions: when the paneling came down, i saw that it was installed with 1x2's running vertically that had been nailed into the foundation. I do not plan on 2x4 framing the walls against the foundation because we're not planning on living here for more than a few years. Id also rather not mess with installing and finishing drywall. What other kind of options should i look into for the walls? Right now im just concerned about the 2 walls that are the foundation because the other 2 walls are already framed. I do not need the absolute best in acoustic materials, i just need something that will suffice for the time being. Any thoughts on what might be a good option?
And for the electric: i currently have a screw-in fuse box (100amp) that will be replaced with a new 40 breaker panel. Im planning on running new 20A wire with a 20A breaker just for the outlets in the room (probably 4). I was planning on putting my A/V equipment in a rack with a nice surge suppressor on one outlet. I will be able to plug in my sub in an outlet that is on a different circuit (which i believe i read is ideal?) However, i dont know where to plug in the projector. Is it best to have that on a separate circuit, or is it ok to add on the same one as the rest of my equipment?
Last but not least, Is a decent carpet and pad enough for the flooring? I have read about subfloors, but i dont have the $ or space to put one in, due to already having extremely low ceilings. Im planning on building a sonotube type subwoofer that packs some good punch.
Well, my apologies for being so long. Im really gearing up for this big time and im very excited to get it done. I really appreciate any input that anyone has!
Thanks!
If youd care to talk on AIM, please message me at SidneyPhive0
Thanks!
