Chris PC
- May 12, 2001
I need cables and/or adapters for my projector that will allow me to place it farther back, against the wall (don't worry, it has no affect on ventalltion.
1) A PC type AC power cord with a 90 degree end going into the projector.
2) A VGA male to female cable adapter that is 90 degrees.
3) A DVI female to HDMI male 90 degrees. Allows me to plug a DVI cable into it and then I plug the 90 degree HDMI end into the projector.
I need adapters that are the shortest distance possible because I am trying to push my projector farther back against a wall.
thanx,
thanx,
