Greg Br
- Dec 13, 2001
YEA BABY, THERE GOES THE FREAKING NEIGHBORHOOD
I want to thank everone who has helped me the last few days. I am sure my frustration was showing thru. I especially want to thank SVS Ron and Tom for all their help.
I bought the SA-155 mini amp from radio shack today, after many girations of making sure the cables were hooked up correct. I hooked it all up, I did not even need to get my master volume to -50 before I knew that my little buddies were back.
Just a small recap, I was running dual 20-39cs off of a sony 100 watt stereo receiver, it sounded great till the Sony crapped out. I ordered the Samson to go with my Yamaha receiver, well the results were not what they should be. I was able to calibrate to 75db's easily but the speakers could not push passed 90db's in major scenes, the only way they sounded good was to crank everything to max.
I hooked everything up and what an unbelievable difference. I whent from having everything maxed for ok sound, to having calibrated on my sub level at -20(lowest) for awsome sound, I have the Samson on full gain and the mini-amp set to 4(out of 10). I have so much room to do whatever I want with the bass, really high calibrations, anything. Music sounds great without having to crank the master volume up to +10 over refernce, it sounds great at -10 from reference.
I whent from 92db's on the T2 thx intro to a whopping 118db's
There has been posts that if you can calibrate then this box will not solve the problem of low bass playback, I think that I can attest that for some reason this is not true. I was lucky I had used a previos amp so I had a good reference to how incredible a prodcuct this is and knew for a 100% certainty that there was a problem
SVS subs rock but it is second to their customer service
Greg Brown
Greg Brown
