Edward J M
- Sep 22, 2002
The meter has a c-weighted filter. Without getting terribly technical, it reads progressively lower as the frequency drops. In addition to the c-weighted filter, the meter has some additional inherent inaccuracies.
There are some correction factors for the RS meter floating around (even the SVS website has it IIRC), that compensate for both the c-weighted filter and the inherent inaccuracies.
The c-weighted filter actually starts to affect the response up around 80 Hz, but it won't become significant until about (as you state) 35-40 Hz. At 20 Hz, I think the RS meter is reading around 8-10 dB low, IIRC.
Also be aware not all RS meters will react the same, so applying a generic set of correction factors to a specific meter will be met with limited success. With that said, for the purposes of basic in-room FR sweeps to identify and correct for large peaks and nulls, it should be satisfactory.
