I need 3 of them to wire up 3 Adcom amps I just bought so I can bi-amp my mains and center. Is there a BIG difference in sound quality between the basic $5 'Y' and the $15 'Y'?
Peace Out~
What I should of said was, would there be a BIG difference in sound quality. But, no matter, I just went and bought the $15 'Y's. BB has 10% off all cables.
Peace Out~
Bruce, cables don't have to be different in length or long to sound different. I am not saying that there is going to be a difference between $5 and $15 Y-adapters, but short cables can sound different.
A high-end dealer in my area has Cardas Y-adapters for $90 each. I hope they would outperform the Monster Y-adapters given the price differential. Cardas makes some great cables.
You can also go to www.vampirewire.com and call them (I think they are in FL and buy their 'Y' Adapters. They have a couple of models. They are a bit better than the kind with cables since there is no cable. It goes from a male RCA to 2 female RCAs and then you just run cables from the female RCAs the same as you would female RCA jacks on a preamp or receiver output. If those are too pricey (I think they are around $20/pair, Parts Express, Link Removed has a cheaper version of the same thing and my recollection is that they are about $4.50 each or $9 for a pair.
Ron
How did the bi-amping go? Is there a big difference in sound quality? I've been thinking about doing the same but I would like to hear from someone who has actually done it.
MIKELink Removed
Mike, I wrote up a quick experience HERE. I have not had any time to really get in and tweak or listen. Plus, I have new interconnects coming in a week.
I had my speakers bi-wired off my Marantz. But, going from a receiver to amps and bi-amping is a huge increase in sound quality.
Peace Out~
