chris larralde
- Jan 14, 2001
Since I'm holding off on the purchase of a new 16X9 set or projector, I decided to tweak my 4X3 Tosh TN50X81 as much as I could.
I've already corrected geometry, 64pt convergence, duvetyne, lens hood, Avia, electronic focus, and general cleaning for dust etc. The only thing left was a mechanical focus of the lenses. I've been holding off because it just seemed too complicated. Well, I was wrong!
I used the string method and found that my red was off by quite a bit, green was pretty good, and blue was okay. Fixing the red really sharpened things up. Everything is much clearer now. The only drawback is that the crawlies on anamorphic DVDs look more pronounced now. I'm using a first generation progressive player (tosh 5109) and judging from other posts, I'm suspecting that this may be the culprit. I also noticed that sharpening the blue added a yellowish tone to the the whites. I read about this on Chris White's site (I think), and I'm going to decide whether or not I'll need to re-adjust the blue.
Well, aside from adjusting the grey scale, I feel that I've maxed out the potential of my set, short of a full ISF calibration. I have to say that I'm quite pleased -- this should make my wait for a new set/projector much easier.
The only thing I'm questioning now is the DVD player. Does anyone know how the new players compare to the first ones? I keep hearing about this "genesis" chip -- what the heck does it do? Do the first gen players have it? Will the new players eliminate all the nasty downconversion crawlies that I see?
Thanks for any comments/suggestion on the DVD player-- and for those who haven't tried the mechanical focus, I would highly recommend it.
chris
chris
