captainkidd
Grip
- Dec 4, 2009
- John
Hello all-
I have posted a similar question in a couple of other forums but had no luck getting recommendations so I thought I would give it a whirl here. Thanks in advance for any replies!
I am setting up a movie/tv/game room and am looking for projector recommendations. I have the ability to black out the room but often times we will be watching sports or playing games with some light in the room, other times watching blu ray movies in total darkness. I was really thinking about something in 1080P but a nice woman at 'projector people' strongly suggested a Panasonic PT-AX200U for my application. She said that only the most discriminating viewer would be able to see a difference between it and some of the less expensive 1080P models like the Mitsu 3800 while watching HD movies and that the Panasonic would be far superior for gaming and sports viewing.
My screen is about 120" diagonal and made of some sort of white, stretchy material made for projection, I think it was called 1X something. The ceiling is 16' high so the projector will be mounted on the opposite wall overhead, about 19' away from the screen with no obstructions to worry about. Viewing will be up to about 15 or so feet away from the screen. We will use it for playing Wii as well so I need some headroom in front of the screen to play without blocking the PJ picture.
Light control is not difficult as there is only one small window in the room but I would like a projector that can perform with some artificial directional light in the room as well as throw an awesome HD movie in total darkness. There is a pool table and dart board in the same room and I want to be able to use them at the same time as the projector. We will watch a lot of sports and HD TV as well as movies on the set.
So with all that said, any suggestions?
