Dave H
- Aug 13, 2000
I was looking at the different aspect ratios on Avia under the "Letterbox Geometry" and would like to know what I should see ideally. As I stated in a previous post, I believe my centering is off just a bit.
While looking at the 1:85:1 screen, here is what I see.
This is kind of hard to explain so bare with me.
On the extreme right side of the letter box, I see the upper right corner, middle side, and bottom left corner have lines on the grid pattern. However, I don't see these lines on the left hand side of the letterbox. Should these other lines be showing? I see the edge of the letterbox on both sides (left and right) but don't see the the lines I mentioned - they are only on the right side of screen - not on the left.
I assume the the lines should be visible on the left part of the screen, as well - correct?
