David Sailor
- Jul 21, 2003
Here's my first post, I considered adding it to Edward's fine thread re: pb2 but decided to start a new one since the only relation to that thread is I will also be the owner of this fine sub, ordered on 7/18 and the wait begins.
My questions: Regarding large vs small, at what size do you decide to set to small, I have seen references that all speakers are set to small when a quality sub is used. On the other hand, my main speakers are Paradigm studio monitors, should they qualify for small? The surrounds are the Titans and I would expect them to be set small, same for the cc 350 center channel. What's to gain by setting the monitors to small?
Secondly, research seems to indicate that if all speakers are set to small, then the sub is expected to play to 121 db, I think, to make up for the lack of bass in the other speakers. What adjustments are made to the sub in this case? Is it set higher so that it's several decibels "hotter" than the other speakers? Sorry for what may be basic questions and the length of the post but am getting anxious to establish good settings when the pb2 arrives. BTW, the electronics are all Adcom, 200 wpc to all speakers. Thanks, David
