Reference level is when you calibrate your speaker levels using, for example, Digital Video Essentials and an SPL meter, the volume and speaker levels at which each speaker reads 75 dB on the SPL meter when playing the test tone from the disc.
As an example, the reference volume level of my speaker set-up and receiver is -2.0 dB on my receiver's dial. At this reference volume level, each of my speakers measure 75 dB on the SPL meter when playing their corresponding test tone if the speaker levels are set as such: Front Left: 0.0 dB Front Center: -2.0 dB Front Right: +1.0 dB Surround Right: +1.5 dB Surround Back: +3.5 dB Surround Left: +2.5 dB
Furthermore, -2.0 dB being my reference volume level on my receiver is also the Dolby reference volume. When I play a movie at that volume it is friggin' loud, so I usually watch movies 10 dB less than reference, i.e. -12.0 dB on my receiver.
Angelo.M, I was using the test tones on the DVE disc as an example. When those test tones are played and the SPL reads 75 dB, that's reference level. That's what I meant, sorry for the confusion.
MuneebM, what is the max. volume setting on your RX-V2400? I'm a bit suprised that at the nearly -0dB setting the level is only 75dB, not that I don't think 75dB is loud but I would have expected closer to 90dB or so. Are those JBL speakers very inefficient?
I recall reading in another thread that someone had the HK AVR630 and measured 100dB at a setting of -0dB, mind you they were using a piece of music in stereo mode not test tones in surround mode.
Howard, the test tones on DVE are recorded 30 dB lower than reference level (105 dB), so at my reference volume of -2.0 dB, they are supposed to measure 75 dB on the SPL meter. If the test tones were 85 dB, as on Avia, they would read 85 dB on the SPL meter at -2.0 db on my receiver, and so on. I'm sure if I had a 105 dB test tone playing, it would measure 105 dB on the SPL meter at -2.0 dB on my receiver.
To answer your question, the max volume setting on the RX-V2400 is +8.5 (if I remember correctly), but that's 10.5 dB louder than reference and I would never watch a movie at that level, as it is much too loud, and there would probably be quite a bit of distortion.
'Reference Level' can be achieved in several ways with varying kinds of equipment, but it all boils down to the same end result. The idea is that when you set your receiver or processor's volume control to a specified level, after you have calibrated the system, the output level you experience will be extremely close to what the movie producer (or whomever is in charge of such a thing) wanted in the commercial cinema. Thus, the sound level you would have experienced in the commercial movie theater is the reference, not taking into account varying levels between commercial theaters.
Whether playing back movies in your home at the same level is desireable is an entirely different question, and completely a matter of personal taste. I find it varies greatly from one movie to the next. For movies without much action, reference level seems just fine to me, as dialogue is easiest to understand and you notice the surround ambience more. With blockbuster action movies though, such as The Matrix, Lord of the Rings, or Star Wars, I tend to find playback at reference level a bit too loud. In those cases, I am typically at -5 to -10dB under reference level. -10dB corresponds to a level that is perceived as half as loud.
Hi, everyone. It's not my thread but it is interesting and informative. Here's my question: So, what about if your receiver auto-calibrates like my Yamaha 2400? what's the reference level there?. I have the Video Essentials DVD; should I recalibrate manually?. I long thought that reference level was the level they use in commercial theaters. If I take my spl meter to the theater, would it read 105db during maximum peaks? So much to learn...
Fernando, when your RX-V2400 auto-calibrates the speaker levels via YPAO: (1) there's no way for you to know what your reference level volume is on the dial (2) the YPAO-calibrated speaker levels will not be as accurate as they can be with an SPL meter and calibration disc
If you want, you can determine your reference level without a calibration disc, but an SPL meter is required. Just play the front left speaker test tone (with the "Test" button on the RX-V2400's remote), set up your SPL meter at the listening position at about a 60 degree angle, increase the volume on the RX-V2400 until you read 85 dB on the SPL meter. That will be your reference volume level, should be roughly the same as mine: around -2.0 dB on the dial. Of course, I still recommend you get a calibration disc (my recommendation is DVE for a 6.1/7.1 set up) and use that instead with an SPL meter.
I've only used YPAO for speaker distances and speaker phase checks, and I plan to try out the parametric EQ some time in the near future, but I truly think my speaker levels set with DVE and my SPL meter are more accurate than those determined by the YPAO.
um, that is highly dependent upon numerous variables. doubtful his "reference volume" will be the same as yours, unless you know more about the rest of his system and ht room than i do.
Step #1) We've realized that we were powerless over our audio buying habits. Step #2) We've made amends to all the local audio dealers that we've said bad things about. Step #3) ...
Shane, this is a ridiculous statement. I really don't think your reference level is -20 on your knob because your speakers are extrememly efficient. There are many receivers out there that have a max volume of 0.0 dB on the dial, so the entire dial range is shifted. For example, my RX-V2400 has a max volume level of +11.5 dB and my reference volume is -2.0 dB. I used to have a cheap Kenwood receiver in the same room with the exact same speakers. The Kenwood had a max vol. level of 0.0 dB and its reference level was -12.0 dB, notice the shift. Are you saying the el-cheapo Kenwood receiver is more efficient than my $1K+ Yamaha? I highly doubt it! Furthermore, I've done quite a few SPL calibrations for friends, and one of my friends has a Yamaha RX-V540 with tiny Paradigm satellite speakers. His dial has a max vol. of 0.0 dB and his reference level is -14 dB on the dial, once again notice the shift as compared to -2.0 dB on my dial with a max vol. of +11.5 dB on my dial. Are his Paradigm satellite speakers that much more efficient than my JBL Studio Series that costed me twice as much? Once again, I really don't think so, because if that's the case I just should've bought those tiny Paradigm satellite speakers!
75 dB as reference is arbitrary, just as the 85 dB THX reference is arbitrary, just as 66 dB (recommended by many folks at AudioCircle and similar "audiophile" forums) is arbitrary.
So, as far as names, you can include anyone who has calibrated their system to THX reference, for example. I'd bet there's at least one score of them.
