JasonG
- Oct 31, 2002
Hi all
Just bought a Sony Wega 32" FS and a Yamaha home theater system. I have a couple of questions. The first one is regarding the subwoofer. Where is the best location for it. Right now I have it behind the couch. Also how do you know what volume you should have it at. Because right now it seems to be to overpowering if you know what I mean. Also when you are getting all the speakers to be the same volume is there a recommended volume for them all to be set at. Should the center channel be louder since the dialog mostly comes from there? Any suggestions would be appreciated.
Jason
Jason
