A
Anthony_Gomez
A few details. Base cube is 23". The inner shell is 5/8" 11-ply BB. the outer shell is 3/4" MDF. I have some wall "braces" running on the "unused" walls using more 3/4" MDF (for 2.125" thickness in down the center lines).
Had some extra egg crate from the Usher project, so I cut it up and "semi evenly" distributed it on all the open surfaces. Not pretty, but it can't hurt
The black is a few coats of black primer followed with a few coats of Duplicolor TruckBed Linner.
The legs and edges are 3/4" walnut. The top is bookmatched resawn walnut (~1/8" thick).
The walnut was sanded up to 220 then finished with many (I forget how many
...maybe 8-10) coats of Minwax high gloss wipe on poly (with the usual sanding and 0000 steel wool).
here are some pics (I kept them under 100k each)
http://www.dslextreme.com/users/louieg/sub1.jpg
http://www.dslextreme.com/users/louieg/sub2.jpg
http://www.dslextreme.com/users/louieg/sub3.jpg
http://www.dslextreme.com/users/louieg/sub4.jpg
...have the PR's at the apartment...now I just need my Tumult :frowning:
