A
Anthony_Gomez
ok....so I was all excited about finishing up my 2way's and stands (http://www.dslextreme.com/users/loui...mrendering.jpg) this weekend. I was just waiting for the 24hrs for the trace solvent to evaporate from the truckbed liner spray (duplicolor...which by the way...makes you high as a kite....even in the outdoors
). 24 house was just about up and I do to move the enclosures to an area to add the guts....but wait..something feels weird....the #$)(*&#*&5 (*%&$#(&%$#985 4a#$(*&($*%#$%&@#95elkfjlsdjf!!!!!!!! ...top coat started delaminating
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!! (insert all the foul language you want).
so why did it do that do you ask...well...when I was at the store, I needed to get some more black primer as an undercoat...the store only had some general purpose sand-able primer (iirc, it has blueish green lettering/images on a white back drop..think generic). It wasn't what I usually used, but I was like.."what the hell. it is just the primer coat".
Well, when I first started spraying it on I noticed that it only sprayed out 20% (tops) primer solids (color) compared to the normal krylon/rustolium stuff. ..the rest was just solvent. #$*&!!! "I'm returning this #$*"....but I decided to finish up the can before running off to other stores to find the primer I wanted.
...so how do I know it was the primer that caused the delamination? Simple, the area that I used it (30% the enclosure) was really easy to re-strip...the other, ..that I used a different primer on...was a biotch to remove!"
...so yesterday, I spent popping the side panels (which was a pain in the arse!), stripping the enclosure down to bare MDF, and re-gluing up the side panels. Since I only get to work on these on the weekends, I have to wait another 2 weeks to get them both up
...the good news is, the first sounds/looks awesome...albeit mono
