A little background. I just had to upgrade cable box and the new 4K box does not use optical which I had running before and I could switch to my SA/CD input that I was running my DJ controller with RCA’s and the TV picture would stay on. Now I’m not sure if it’s because of the box change or I inadvertently switched settings on the receiver?What is the make and model of the receiver? Some manufacturers allow a video source to play through on an audio source. Which means you could have the game play through on the music input.
So now I really have got myself confused but have figured out a way to make it work. As long as I run my HDMI directly from cable box to TV and PS5 HDMI to another port on the TV and run my optical for audio from TV I can have the TV playing and switch to another input on my receiver and play audio. When I use the ARC function the second I switch inputs the screen will go black.Just to add, without digging deep into the receiver's manual. sometimes they have a "Simulcast" feature, where if you choose a video input, then select an audio only input, it continues to send the video source through the hdmi output, but plays back the audio input through the speakers. The thing is, you have to select the video source first. I don't know if your receiver has this feature, but based on how you said it used to work, it sounds like it does.
Haha it’s a lot. You can’t read(decipher) what my current set up is?…pretty much. I like to believe I understand the options rather well, but I don seem to be able to read what you did.
Just based off everything I’ve attempted it appears that as long as I’m running the video source through the TV and not through the receiver and back to the TV and then running the audio through the TV’s optical to the receiver then I can watch the television and still switch to another input to play external audio source. Thinking back I had to have been running it this way with my old setup…pretty much. I like to believe I understand the options rather well, but I don seem to be able to read what you did.
Yes. That was the basic idea.Just based off everything I’ve attempted it appears that as long as I’m running the video source through the TV and not through the receiver and back to the TV and then running the audio through the TV’s optical to the receiver then I can watch the television and still switch to another input to play external audio source. Thinking back I had to have been running it this way with my old setup
You have to run a separate set of speakers for thatYou could use zone-2 for the audio. Maybe that's what you were doing before?
