Roger P
- Apr 9, 2002
I'm planning to get Sony WEGA flatscreen TV, but I notice that it only comes with one component input in the back. Is there a switchbox available that allows me to connect multiple devices?
What "ohm" is standard Component cable?
All video cables should be made with 75 ohm coax cable and hopefully with good RCA plugs.
The wrong cable does not loose signal (not with these short runs in your home), but it can cause some frequencies to reflect inside the cable. The simple symptom is a "ghost" on your picture.
While they sell professional grade stuff, check out Link Removed .
