ClayC
- Jun 20, 2000
I'm in the process of designing my built-in entertainment unit and am planning on putting two rack mounts on either side of my wide screen. Since there will be no access from the back, they will need to slide out. Also, they will be several feet of the ground, so they will need to be self-supporting. The only ones I have found are at Smarthome.com. (http://www.smarthome.com/8746srxx.html) Anyone know of other sources or other ways of accomplishing this?
Also, any thoughts on heat dissipation with two racks of equipment and a Toshiba TW65X81 all built in?
Clay
Clay
