Chris Tsutsui
- Feb 1, 2002
The unknown AV3 loudspeaker rises from secrecy to do battle with the closely priced JBL S38. Read on to find out if this kit will live up to the expectation to compete with Paradigm 100s and B&Ws, in which case certain annihilation of the S38s is eminent.
Hello, In case you don't know me I spend most of my time in the DIY and Speaker forums trying to go as deep in the audiophile rabbit hole as possible. Today I just heard my first hour with my now fully assembled GR-Research AV3s. Soon I'll be doing a more in depth review but for now I'll post my inital impressions and build. The speaker I can direct compare these to is the JBL S38 which I purchased for $245.
Kit arrived this Friday after ordering them on Monday, shipped UPS. Total came up to $340 + $33 for MDF and fiberfill making a grand total of $373 for the pair. Kit included wire, speaker terminal, spike stands, and not to mention flashy gold emblems, solder and shrink wrap tubing. The wiring diagram was fairly easy to understand though it did take some thinking in assembling the crossover.
The building instructions were very easy to understand and it only took myself and my friend 8 hours to build two pairs of enclosures. (One pair is for the builder and one for me) We only had the parts for one kit so only one was fully completed. Sometimes I find it hard to believe how fast we work on projects like this, I guess it helps to have a master carpenter as a friend.
(I took pics of the build process and parts so they'll be added to a page soon enough)
Well let me start...
First the vintage equiptment list:
Stereo Amplifier: Pioneer A-X900 (about 55 watts x 2)
DVD Player: Sharp DV-710 (can't play CD-Rs and no optical or component video out!)
Generic 16-18ga radio shack speaker wire
I know some of you might be asking why does this guy use such horrible equiptment? Well, at least when you listen to them on your equiptment it'll sound better and you don't have to worry about me using $10k equiptment some can't afford. Besides this is my temporary downstairs jig. Tomorrow I will be moving them upstairs to a dedicated HT where they'll be teamed with some decent Rotel separate amplification and full blown acoustic treatments.
Upon first firing up a random CD I found nearby (Titanic Soundtrack) I noticed an immense warmth in sound during music. Before I concluded that that's how I wanted to describe them I thought about break-in and then began to swap some other CDs such as Andrea Bocelli, Avril Lavine, Diana Krall, Brian Setzer, and some other soundtracks.
I still concluded my S38s sound not only bright in comparison, but the highs are just plain raspy and artificial. When comparing, the S38s sound grainy, the vocals are coarse and the highs are a lot more fatiguing. It's as if I can listen to the AV-3s at a much louder volume, and longer periods of time than the S38s. My taste for music is that I LOVE warm sounding speakers as long as they stay away from sounding muffled or restricted of highs. Perhaps the highs could be a little more enhanced but then I'd fear it would take away from the immensly euphonic (pleasing) sound.
The AV3s were remarkable upon my first critical listening session, to describe how it sounded would be like having a huge dampening wall and discrete sounds coming from different locations. The isolation was like adding cubicles around each music source so I could acoustically locate them, and easily focus in and out of them. Rather than having overlapped sounds playing from different locations, the sound was more focused as well as I could differentiate what was an echo (reflected sound) and what was direct. The depth was an immediate improvement since I never heard sounds come from behind the back wall before. However the width of the sound stage seemed the same, and the width of each source was the same. The main difference was the separation.
The Bass extension is a -3db down point at 40hz while the JBls are posted down to 45hz. To me they both performed very close with regards to bass and I'd highly recommend a separate subwoofer for either. Because the response was so close, it was easy to compare them and notice that they both produced voices/tones the same way, it was just that one was more articulate in doing so. The mid to upper bass was very clean and smooth, much similar to the JBL though the S38s were a tad lumpier/muddier (Barely). It was the upper-mids and highs that had the startling difference.
After music I fired up Star Wars TPM and Time Machine in 2 channel stereo mode. My first reaction to the AV-3s was that it made the room feel like it was acoustically treated. The sounds were discrete and clearly separated from eachother and I could clearly hear more details and isolation of voices. The left right transfer of sound was seemless just like the S38s though the depth of sounds was better. I played the pod race scene in pitch black so that I could visualize from just the acoustic information. During a couple parts I could easily tell how the pods were moving and where. This could also be done on the S38s but not without some ear discomfort. I could easily "listen" to an entire movie through just these speakers which was only done previously on my Sennheiser headphones. A funny point to mention is during "Time Machine" I wasn't paying attention and the main character said "Hello?". I turned my head and scanned the room because I literally thought somebody was in the room.
Though I have not directly compared these speakers this is purely by memory of previous auditions: I prefer the sound of the AV-3s over Paradigm Studio 100s, Martin Logan Aeons, Energy Veritas, and Monitor Golds. Keep in mind the current equiptment used for audition of the AV3s are very low end and the room and placement were not exactly ideal. I could easily hear humps/dips in the response but my emphasis wasn't about testing response or noticing slap echoes.
In conclusion I'll rate them:
Out of 10 I give the JBL 8 for being the best commercial speaker I've heard for under $250. Their sound is accurate to how I want it to sound with regards to pitch (frequency), but the timbre (quality) could be improved in the upper spectrum. They're great for casual enjoyment or the average enthusiast but I have been aching for something more. It was the day when I just couldn't enjoy music like I used to when I decided to shop for a DIY solution.
The AV-3 outperforms the JBLs in all aspects, in some ways more than others. I'd give them an initial 9 as I do feel that they arn't significantly better than other $2,000 speakers in the price range. I believe that the highs could be a pinch more live/forward in the AV3s. I'm really impressed with the similarities the AV3s have with quality headphones. Listen to any pair of $100 and up Sennheiser headphone and you'll hear a similar pleasing sound. To me, It is the soundstage and presence that puts the enjoyment of the AV3s over headphones. Like most speakers, it isn't perfect, but it did met all my expectations.
I would definitly pay an additional $100-200 to upgrade S38s to AV3s. $500 would be pushing it and I'd rather buy the S38s. (However, I still love my JBLs and won't be parting with them anytime soon [surround duty])
Of course this is my preliminary review as there'll be another when I use the better room/equiptment and can direct ABA test them again with them all broken in. Sorry for being blunt, I have some enjoyment and breaking in to do... Yep, I havn't done any enjoying yet... only critical listening.
Did you really read all of this? You must be as bored as I am an audiophile. jk
