James_Kiang
- Aug 29, 2000
So, after some back and forth, my wife and I decided to go ahead and pick up this 37" LCD made by Hewlett Packard. Right now we are still using the old cable box we had but I'll call Adelphia and upgrade to the HD box and that should improve our regular tv picture (right?).
My question is about the inputs. There are 5 inputs on this tv:
1 - Component (can also take composite)
2 - Component (same)
3 - S-Video (same)
4 - HDMI (with separate audio inputs)
5 - HDMI
Right now, this is what I have connected:
1 - DVD (component; Toshiba SD-1200)
2 - Xbox 360 (component)
3 - VCR (composite)
4 - nothing
5 - nothing
I have a PS2 I wanted to hook up to the tv, but I'm using composite connections for it and there are no open composites left on the tv. I also just read another message that made me think that the HD cable box shouldn't be connected to the tv using the coaxial connection (right?).
So, what do I do to get everything on this one tv? I was thinking I could get a new dvd player with upconversion, which would end up using one of the HDMI inputs. That would free up a component connection I could then use for the PS2. The only thing is that if the HD box needs that connection the PS2 is still out of luck. I suppose I can try to find out from Adelphia when I schedule them to come out to switch boxes if there is an HDMI on the box. The prospect of buying a new dvd player and two hdmi cables isn't going to sit well with my wife....
3 - S-Video (same)
5 - HDMI
3 - VCR (composite)
4 - nothing
5 - nothing
