Andrew_Ballew
- Feb 21, 2002
What do you consider an acceptable level of hum in your speakers? (Other than none ) I have a Carver 806x amp, and I get a small amount of hum in my center and surround channels. It is practically inauible with no sources engaged, likewise with just my Newcastle Pre-pro engaged. But when I engage a DVD, the hum rises from near inauible to audible from within 1 foot of the speaker. The hum does not increase along with the system volume, so it is really a non-issue, but I know it is there, and that is enough to drive me crazy. I have tried all the usual ground loop remedies (except for the cheater plug, as I see no use since the amp's plug is already two prong) to no avail.
Would you consider this level of hum acceptable in your setup? Or should I just live with it? Might one of those power conditioners I hear so much about do anything at all to improve the problem? How about balanced power? But thats really expensive, isn't it? Haha- the joys and aggravations of this hobby.
Andrew Ballew
Andrew Ballew
