Troy_K
- Jan 20, 2002
Ok gang. I'm no stranger to HT, and I'm no stranger to calibration with an SPL meter. I just want to share my thoughts about my recent purchase of Sound and Vision's Home Theater Set-up DVD changed my HT.
I had used VE in the past, as well as THX optimode. The VE was with my old set-up, so that's a mute point. I don't have it any more. I had my current HT setup calibrated with the Denon's internal tones, but the bass seemed low, and I had to boost it about 5 more db to be satisfied.
With the new setup DVD, speaker levels were within 1 db or so of being the same as the Denon's tones, but the difference was in the subwoofer settings. This DVD has various subwoofer set-up options, which are great! The final result was that when set to the SAME level as my mains, no HOT settings, my subwoofer level had to be boosted +5! That was about an 8 db difference when compared to my internal test tones. I imagine that the DVD was able to sample my subwoofer over a broader FR, rather than focusing on my in room peak that I have at around 70hz that my Denon was likely picking up.
Now, my HT is awesome now that it's properly calibrated. My bass is so enjoyable and really kicks ass. Thanks SVS and Sound and Vision for a great combo. Of course the Klipsch and Denon components rock as well.
BTW, the new DVD software's tones had to be adjusted at 85 db to get the same levels as my internal tones at 75 db.
Troy
Troy
