Jay Mitchosky
- Sep 6, 1998
Hey All
I recently installed the Model 9871 HDTV distribution system from Audio Authority and am thrilled with the results:
In a nutshell it allows you to distribute HDTV component video and digital audio via CAT-5 cable to dedicated wall outlets throughout your home. One CAT-5 driver (shown above) will accommodate up to two (2) wallplates:
You can daisy chain additional drivers through the bus connection for larger systems:
I have a HD-PVR satellite receiver for my home theater. Instead of adding another receiver for the rec room (which would be a problem as I've run out of satellite feeds) I opted for the Audio Authority solution. Installation is straightforward:
After powering up the 9871 everything worked perfectly. Full HD audio and video is simulataneously displayed (without delay) in both the theater and rec room. If there is any degradation in image or sound quality I can't notice it - everything seems the same as it was when directly connected. CAT-5 cable is cheap and easily available. Audio Authority claims distribution of up to 1000 feet (there is actually a cable length compensation dial on the wall plate with ten steps of 100 feet).
If you're looking for an effective way to move HD audio and video around your house from a central location the Model 9871 is well worth a look. And don't be afraid to give them a call as their technical support was exceptional.
Here's a few quick pictures of my installation for reference.
- Run two (2) lengths of CAT-5 or CAT-5e cable from the source location to the distributed area. In my case I have a wood basement floor and was able to run the cable underneath. For new home construction you could prewire. For existing home construction you will have more challenges depending on the two locations.
- Terminate the CAT-5 cables at either end, ensuring you mark one in advance to differentiate between A and B line.
- Connect the CAT-5 cables to the wall plate (installed in a dual gang box).
- Install the Model 9871 at the source component and connect component, coax digital, and CAT-5 cables.
