Paul_Stachniak
- Feb 7, 2003
I didn't mean it to be hostile.
Two common ways that the average levels can be cranked on a DD track are via dialog normalization and some form of dynamic range compression (typically peak limiting with look ahead limiters).Dialog Normalization is an attenuation system. It doesn't/can't increase playback volume.
Adam
I think dolby suffers from the necessity to have to downmix to anything.Amen. The nice thing about LaserDiscs is that the people who owned them were pretty much all audiophile freaks. The curse of DVD is that it is popular, and therefore has to "sound okay" on anything and everything.
I remember getting my THX Star Wars LD and thinking "Man, this sounds pretty weak," and then I got a new amp and preamp (I was using a cheap-ish pro logic all in one amp before) and spun Star Wars and went "Holy crap, this sounds way better."
It was like night and day.
But then GoldenEye, which had sounded killer on the old amp, sounded perversely overcooked. It was, as far as I can recall, the only disc that was not improved with my better system. But when the vast majority have inexpensive gear, why wouldn't you want to make your stuff sound best for them? What's the point in optimizing it for the handful of picky folks?
But when the vast majority have inexpensive gear, why wouldn't you want to make your stuff sound best for them? What's the point in optimizing it for the handful of picky folks?Because a track that sounds killer on great equipment will sound killer on just about any equipment whereas a track that is optimized for bad equipment will sound bad on good equipment. Otherwise, they may as well optimize for tracks to be played through tinny TV speakers.
Because a track that sounds killer on great equipment will sound killer on just about any equipment whereas a track that is optimized for bad equipment will sound bad on good equipment.So explain GoldenEye. Tracks that I now recognize the full brilliance of sounded bland or mediocre on my old system. Some tracks, like GoldenEye and the PCM track on The Phantom Menace sound so overcooked on the good system but sounded great on the old system. These same complaints surface about certain new DVDs being overcooked or overly bassy, but they sound really "good" on weaker systems.
So explain GoldenEye. Tracks that I now recognize the full brilliance of sounded bland or mediocre on my old system. Some tracks, like GoldenEye and the PCM track on The Phantom Menace sound so overcooked on the good system but sounded great on the old system.My explanation: Without being able to verify, I am guessing that your old system was not as good as your new system. I bet if you went back to your old system, the stuff you thought sounded great would not sound so hot anymore, and you would also like some of the stuff that you previously dismissed. Your ears are now used to being spoiled. I have not personally ever had an experience like you described with one of my system upgrades, so that's all I could come up with.
loud is goodNot at the expense of reasonable dynamics. The "loudness" that most people are complaining about is the result of digital peak limiting or other forms of dynamic range compression. It actually sounds worse and more unnatural the louder you turn your amp up, because it robs the sound of its impact. In addition, because of the constant high RMS level, it is more likely to lead to hearing loss with prolonged exposure at high levels. You can make every film sound like this by selecting "midnight mode" or "max dynamic range compression" on your player or receiver, but there is no reason to build it into the software. If I want it loud, I'll turn the volume up.
On laserdiscs, where the bitrate was substantially higher for DTS, the differences between DTS and DD were significant.This contention is not supported by listening tests done by Warner engineers. They found no significant difference between full bit rate DTS (which has a HIGHER bit rate on DVD than on LD) and DD. As others have said, it's the mix, not the bit rate.
